Re: Adding Behlen PS to 1951 M w/live hydraulic on distri...
Posted by Jerry Deimerly on August 31, 2008 at 07:01:32 from (67.142.130.30):
In Reply to: Re: Adding Behlen PS to 1951 M w/live hydraulic on distri... posted by Allan In NE on August 31, 2008 at 06:47:56:
Thanks, Allen. It looks like the oil in the Behlen unit is a light clear hydraulic oil, however the live system on the tractor has 30 wt non-detergent in it. Do I switch the whole system over to the lighter oil? There is a loader on the tractor so I would need to figure out how to get rid of the oil in the cylinders, hoses to the back outlets and cylinder on the sickle mower if I need to do that. (I assume I don't want 30 wt in the steering unit). Rather than eliminating the pump, it almost seems like the vertical distributor is less of a issue, but I don't know if that definitely will work either.
