Re: Need some Farmall 460D help
Posted by MRV on September 03, 2008 at 08:06:50 from (130.15.62.247):
In Reply to: Need some Farmall 460D help posted by MRV on September 01, 2008 at 06:01:37:
Thanks Arkie! This 460 has the D236 in it. From what I have been told to change the fuel filters is to turn the fuel off, change the cartridge filters, put the canisters back on, open the bleeder screws and turn the fule back on. Let the filters fill up and close the bleeder screws once a steady flow of fuel starts to come out. Sound correct? There is no manual pump at the filters to fill the filters up. I guess it's a gravity type system.
Another question is how do I check the fluid level in the hydraulic system and the rear end? I thinl I found the filler hole but no dip stick or whatever to check the fluids.
Thanks!
