Re: Cub Coil Kluge
Posted by mkirsch on September 04, 2008 at 06:06:49 from (64.80.110.50):
In Reply to: Cub Coil Kluge posted by Michael Adams on September 04, 2008 at 04:46:42:
The coil normally sits directly on top of the distributor, bolted to those holes you mentioned, through the strap that's wrapped around it.
It's a tight fit, but you can probably eliminate that honkin' chunk of aluminum and get the coil out of your field of view by bolting it direct to the distributor.
