Re: Farmall 504 Weak Hydraulic Continuin' Saga
Posted by Hugh MacKay on September 06, 2008 at 15:12:18 from (209.226.247.148):
In Reply to: Re: Farmall 504 Weak Hydraulic Continuin' Saga posted by TractormanNC on September 05, 2008 at 04:39:48:
Tractorman: The 504 is top link sencing, right or wrong? I didn't have my 504 long enough to find out. I know 656 and large chassis were all lower link sencing. The only three I ever used on semi-mount plow were 656, 766 and 1066. At about 4-5 mph if you pulled hitch and remote at same time, hitch went all the way to top before the remote cylinder at back of plow started to lift. This worked well on 5 bottom plow, as it ended all furrows at same point. Made for nice square headlands. For that reason, I determined there has to be a fluid connection between hitch and remotes. It was the same going into the soil, hitch went first before rear remote started to lower.
