Re: Farmall 504 Weak Hydraulic Continuin' Saga
Posted by TractormanNC on September 05, 2008 at 04:39:48 from (209.42.180.26):
In Reply to: Re: Farmall 504 Weak Hydraulic Continuin' Saga posted by Hugh MacKay on September 05, 2008 at 02:29:21:
Hey Hugh,
Going from memory alone as my books are at the shop.
On the large frame tractors 06,56,66 the front pump powers the TA, P/S, brakes, lube, feeds the oil cooler, Ithink that's all. The rear pump powers the 3pt and remotes.
On the 656, the front pump powers the P/S thru a flow divider and then the remotes. The piggy back pump powers the 3pt and the internal plumbing is such that the rear pump can feed thru a check valve into the remote circuit when the hitch is not being used> Not the other way around because of the check valve.
On the 504, I don't think the hitch pump can feed into the remote circuit but I am not sure.
As far as the semimounted plow, have NO experience. We always used chisel plows and heavy disc harrows around here.
