Posted by Hugh MacKay on September 07, 2008 at 13:34:16 from (209.226.106.34):
In Reply to: Re: Leaking 140...??? posted by KRS_MED on September 07, 2008 at 05:03:21:
Keith: To start with, you put about a pint in the PTO-pulley gear box. It has an overflow into the transmission and a gear in the transmission constantly fills PTO-belt pulley to level.
To make it right, get a catch pail remove the transmission-rear end fill to level plug and drain off the excess. Remember it is the small plug, just below front tip of left fender. Brake activation rod hides it quite well. Then remove each plug on final drives and drain off any excess. Then operate the tractor and come back and tell me if you have any leaks. Don't just drive it around the barn, work it a couple says before you come back.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
