Posted by KRS_MED on September 07, 2008 at 05:03:21 from (74.244.168.169):
In Reply to: Leaking 140...??? posted by KRS_MED on September 06, 2008 at 06:04:20:
Mr. Hugh,
Thanks for the information very much. I guess i am still not sure what is going on. I can't find either of my manuals at this time so I don't have a lot of information. When I started using the 140 to bush hog a rear PTO seal was leaking so I replaced it and re-filled the gear oil at the fill plug on top of shifter plate. Filled it to were I could just see it touch the bottom of the gears. From what I think I get from your post i over filled it by doing that? I have seen the plugs you are talking about on the finall drives, but I was under the impression that the transmission and the drives were all using the same gear oil from were I filled it. So what do i need to do to get all right and back to the way it was meant to be?
Again Thanks so much for the help..! As much as I have read about this tractor I still have a lot to learn...!!!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
