Re: Gas use
Posted by Country Nate on September 10, 2008 at 05:56:16 from (206.224.20.9):
In Reply to: Gas use posted by relaurain on September 08, 2008 at 18:02:09:
Hugh,
I understand the old saying "believe none of what you hear and half of what you see."
So if I had to choose Nebraska test results or somebody's hearsay. I'll go with the test results.
Nate
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
