Posted by Hugh MacKay on September 10, 2008 at 14:58:32 from (209.226.106.71):
In Reply to: Re: Gas use posted by Country Nate on September 10, 2008 at 05:56:16:
Nate: The Nebraska tests were quite good, however you can not take them to the field. Besides what you are reading from a book is a condenced reoprt and doesn't tell the rest of the story.
During my farming career my 7 tractors, probably clocked 100,000 hours,maybe be closer to 125,000 hours if I took time to add them all up. That was 7 tractors at same time, I actually owned 19 of them during my career. I never owned a 6 cylinder gasser, however I've heard planty about them from farmers I knew well.
I did own a Farmall 300G and on my 9' NH 460 haybine it would burn 3 gph. My 656D on that same haybine burnt 1 gph. I kept very accurate records of every gallon of fuel used. The 656D was faster and cut 20% more hay per hour than the 300G. I think you can see why my 300 was the last gasser over 30 hp that I used on my farm. My 560D was cranking 90 hp and it was awfully hard to put 2 gph through it, very rarely did it ever happen.
Obviously you have not operated many of these tractors, should try it, would be a good education for you.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
