Posted by old on September 10, 2008 at 09:27:56 from (4.245.4.125):
In Reply to: Farmall 460 Clutch posted by Help Me on September 10, 2008 at 08:42:06:
First off block the pedal down for a few days, then stat it in gear and take it for a drive, it will probably brake free if you drive it around for a while just be sure your out where you can drive it for awhile. Also if you could hook up something heavy behind it when you drive around that helps. Another thing you can do that works some times is pull the starter off and spray brake cleaner into the clutch area and that some times will brake it free. The from now on when you part it block the pedal down so it doesn't do that again. That's a very common problem on old tractors BTDT many times
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
