Re: Farmall 460 Clutch
Posted by Mike (WA) on September 10, 2008 at 09:49:50 from (69.10.198.224):
In Reply to: Re: Farmall 460 Clutch posted by old on September 10, 2008 at 09:27:56:
Once you've got the starter off, it's pretty easy to just fix it, rather than hoping the brake cleaner will do the trick. Get a thin-bladed kitchen knife (preferably one that the Mrs. is not particularly fond of), heat it and bend it at a 90 degree angle about 2 inches from the tip. Tie the clutch pedal down. Then you can work through the starter hole, in the openings between the pressure plate and flywheel, and work the knife blade in between the clutch disc and flywheel, rocking the knife gently as you go. Rotate the flywheel with a large screwdriver on the gear teeth as you get each section freed up, and you'll soon have it loose. Save the "tool" so you don't have to trouble the domestic partner for another, next time.
