F-12 problems
Posted by S.Gross(in pa) on September 13, 2008 at 14:28:18 from (208.101.145.138):
i have 2 F-12"s a 1937 that has a cracked block but is free. and i have a 1938 that is good but stuck. I would like to fix the 1937 and use the other for parts.should i get the engine welded or use the other engine i would like the numbers to match. I am unsure what is best.
