Re: F-12 problems
Posted by Athol Carr on September 13, 2008 at 16:37:37 from (122.57.104.128):
In Reply to: F-12 problems posted by S.Gross(in pa) on September 13, 2008 at 14:28:18:
My 1937 O-12 had a crack in the water jacket just above the fuel pump. The service engineers had to hot tank the engine 3 times to get the old sleeves out, then had the crack welded, cannot see where it was now. Seems to be a very common problem or weakness with these engines. I have seen many with copper patches riveted on or other fixes.
