Re: Checking Oil on International 656
Posted by Farmall JD on September 13, 2008 at 18:48:53 from (198.208.159.17):
In Reply to: Checking Oil on International 656 posted by CDH on September 13, 2008 at 13:06:53:
Well with our 674 I put it down all the way. I doesn't matter if it is warm or not. The filter will have the oil it has once it has ran at all.. I would see if you can syphone some out to see if it is milky. I was checking our 674 one day while changing the Altinator and it was high.. Took a sample out and it was milky. There was a seal around the sleave that let go and dumped coolant into the oil and that is why it was high.. Plus if it is a Diesel use only approved coolant and oil for a diesel, that way it has all the additives in it..
