Posted by 510 plows on September 16, 2008 at 10:11:36 from (134.29.140.76):
In Reply to: Get the rod out? posted by Mac DeBusk on September 16, 2008 at 04:46:00:
An item that was not mention that will prevent the engine from turning backwards is the sprag in the TA. If your tractor has a TA and the SPRAG is GOOD it will prevent the engine from turning backwards. Pulling the TA lever to the rear will release the TA clutch alowing the unit to turn backwards. Bottom line is, like already said, the engine has to be pulled out to remove the crankshaft from the block and have the crankshaft reground for undersize bearings.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
