Farmall 706 governor
Posted by Curt Cooke on September 16, 2008 at 12:05:04 from (64.186.50.66):
Governor on my 706 is lazy. It waits too long to react to a load, then it over-reacts. Engine speed is inconsistent. I've replaced the spring but that's really all I've done in an attempt to correct it. What's the secret?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
