Re: Farmall 706 governor
Posted by the tractor vet on September 16, 2008 at 19:08:02 from (75.19.124.96):
In Reply to: Farmall 706 governor posted by Curt Cooke on September 16, 2008 at 12:05:04:
Well have you tryed synchronizing the carb to the gov. Pull the throttel all the way open with the engine off , remove the pin on the clevis and open the carb wide open and see if the pin will just slide into the hole if it does not then adjust the clevis till it does then add one half turn and put the pin back in .
