Re: 656 or 560
Posted by Hugh MacKay on September 16, 2008 at 17:11:15 from (209.226.247.13):
In Reply to: Re: 656 or 560 posted by karl f on September 15, 2008 at 21:31:49:
karl: Right on, we know from the past rear chassis was the weak part of the 560. I'll put my money on a 656 anyday over a 560. My 560 IPTO required 5 clutch packs in 17 years. When my 560 - 282 engine blew up in 1978, (2 pistons out in the yard) used 282s were not plentiful back then. IH wanted $4,000. for a short block. I would have had to use my head, injectors, pump, water pump, etc. I could not see spending $4,000. plus labour, on a tractor without IH CatII 3 point and having that old clutch pack IPTO. Also IH had a 2,000 hour 766 diesel for $9,000. and my 560.
