motor knocking!
Posted by bdunegan on September 19, 2008 at 08:23:06 from (164.58.165.218):
this is not the right forum(tractor wrong color) but i cant get an answer on the other one. working on a tractor for friend. had it running three times with no knocks at all, but carb needed rebuilding. rebuilt carb, started tractor, and it is knocking. almost like a rod noise. drained oil,(almost pure gas) pulled pan, and everything looks fine. can get no slack out of rods, pistons, rod bearings or anything. pulled valve cover, and everything seems fine. but still has knock. all i done was rebuild carb. tractor ran fine with no noise the day before, now a knock. is it possible that the gasoline just washed all coating off internals, thus the knock? cant see a rod just turn loose all at once!
