Re: motor knocking!
Posted by El Toro on September 19, 2008 at 10:22:30 from (64.12.116.73):
In Reply to: motor knocking! posted by bdunegan on September 19, 2008 at 08:23:06:
While you have the pan off take a look at the rod bearings to see if they worn or the rod journal is scored. Do one at a time and make sure you reinstall the caps in the right direction and if they look ok retorque the rod bolts too. Pull the main caps too if you can get them off. Hal
