M shifting problem
Posted by NWIA on September 22, 2008 at 05:32:34 from (74.45.253.173):
A freind has an M that is infrequently used for long periods of time on his acreage. After warming up a bit pulling a spring tooth it gets progressively harder to push in the clutch pedal and shift. I told him to check the rear end oil level and beyond that I wonderred if any obvious solution would occur to the wise men here, thanks
