Re: M shifting problem
Posted by Red Mist on September 22, 2008 at 16:10:12 from (67.142.130.44):
In Reply to: M shifting problem posted by NWIA on September 22, 2008 at 05:32:34:
NWIA said: (quoted from post at 05:32:34 09/22/08) A freind has an M that is infrequently used for long periods of time on his acreage. After warming up a bit pulling a spring tooth it gets progressively harder to push in the clutch pedal and shift. I told him to check the rear end oil level and beyond that I wonderred if any obvious solution would occur to the wise men here, thanks
Has he been greasing the throw-out bearing and clutch linkage pivot points like he is supposed to? (See Operator's manual.) mike
