Re: Farmall Super C gear/bearing issues Metal shavings
Posted by DRC on September 23, 2008 at 09:53:04 from (24.165.129.15):
In Reply to: Farmall Super C gear/bearing issues Metal shavings posted by codyNC on September 23, 2008 at 05:47:18:
If you've got it torn down, I think most folks would agree it's a good idea to replace ALL the bearings (including final drive). My local bearing distributor was able to cross reference all bearings on my SC. This may help the whine, but some whine is normal for these tractors.
I'd probably look at the shifting forks first for the hard-to-shift part. Excessive wear on shifter, detent balls & springs working properly, etc.
The sliding gears will also all show wear on a machine this age, but they're pretty bulletproof and should work fine unless TOO bad.
Good luck.
