Re: Farmall 300 Clutch Slips When Plowing
Posted by Bill Lisbon on September 24, 2008 at 20:20:09 from (69.89.162.185):
In Reply to: Farmall 300 Clutch Slips When Plowing posted by Andy Motteberg on September 24, 2008 at 19:59:41:
Before doing anything make sure to adjust your clutch, make sure you have free play at the pedal. If this does not help you need to split tractor and replace both pressure plate and clutch disc. I would put a new throw out bearing and a pilot bearing while your in there. Check rear engine seal and transmision seal, nothing messes up a new clutch like leaking oil. Good luck !
