International 300 Utility TA Lubricants
Posted by Jcip on September 28, 2008 at 14:10:10 from (72.231.145.53):
I am wondering what fluid to put in reservoir under the TA? There is a small area there that held some old gear oil before, and also do not know level required? The PTO gear area also has a reservoir, I assume same gear oil and then what level or quantity? I am having an issue with gear oil leaking out the two drain holes under the TA clutch, and am thinking it is coming from the PTO side, thru the seal there into TA area? Any assistance would be appreciated. JC
