Re: Weight of Fast Hitch
Posted by Farmall Freak #1 on September 29, 2008 at 15:04:23 from (64.12.116.73):
In Reply to: Weight of Fast Hitch posted by Mark from WI on September 29, 2008 at 10:52:48:
I have the fast hitch on my 300 and I make the 5500 pound class with a set of rear weights. It has always done way better than my straight drawbar tractors mostly because you can get it right to the max height and make adjustments with the touch of a lever. If I was going to cut weight I would put tin wheels and 18.4-38 rears on it.
