Re: Weight of Fast Hitch
Posted by Mark from WI on September 29, 2008 at 15:39:59 from (72.160.255.99):
In Reply to: Re: Weight of Fast Hitch posted by Farmall Freak #1 on September 29, 2008 at 15:04:23:
I can get into 5500lb class if I remove all weights and fenders. I did that last weekend and did real well. I got 4th out of 11 tractors. Plus I like the way the fast hitch pulls. I never spin out and the tires I have on there don't loosen up the dirt to pile it up in front of the sled. I do have a wide front end on it so that would weigh more than the narrow. I can't use 18.4 38 unless I want to pull in the open classes which I don't. I have 15.5's on it now. But the pull we have here locally won't allow me to use the TA in the stock class. Otherwise I would do alot better. Do you think I could shave 500lbs by losing the wide front?
