Re: High pitch Hydraulic or Gear noise after new pump ins...
Posted by Janicholson on September 30, 2008 at 20:00:57 from (66.173.50.135):
In Reply to: High pitch Hydraulic or Gear noise after new pump install... posted by charles todd on September 30, 2008 at 19:16:57:
FLowing substantially more oil through a system can cause serious destructive cavitation. Sharp bends (as the metal Elbow on the line) can do it, as can a diverter designed for 12, running 17gpm. A higher capacity priority valve, and a more hydrodynamic fitting might do it.
With that said, there are some serious noises made in hydro systems that cause no issue. If the system is heating up abnormally, I would worry enough to fix it. If the whine is obnoxious, I would fix it. If neither, I would probably live with it. JimN
