Posted by charles todd on September 30, 2008 at 19:16:57 from (205.242.95.138):
I replaced my 12GPM pump with a fresh 17GPM pump on my Farmall 504 recently. I bought both pump cover gaskets (.019 and .024) and used the original gear. The gears looked good and I think I used the .019 gasket. I put in new filters and all new orings. I believe the original style filters are only good for the 12GPM pump. I called (Precision Products?) who make a spacer that allows use of a larger, modern filter that can handle the flow, but is backordered.
I have said this to get to the problem. When running there is a high pitched whine that sounds like it is comming from the flow divider.
I had my father listen to it and he thinks it is from the increased turbulent flow though the rubber hydraulic hose (not stock) causing the noise. I think it may be the gear mesh is too tight transmitting the sound up the hose. Or it could be the flow divider some how resonating? Or the pump is starving with the smaller filters...
Is this normal or acceptable with a new pump? The hydraulics are FAST and the steering works much better. It just has a whine now.
I know Hugh, Allan, Rusty and the like can probably help here.
Thanks and I apoligize in advance for the long post,
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
