Re: High pitch Hydraulic or Gear noise after new pump ins...
Posted by MN Scott on September 30, 2008 at 20:29:33 from (206.9.216.64):
In Reply to: High pitch Hydraulic or Gear noise after new pump install... posted by charles todd on September 30, 2008 at 19:16:57:
If I remember correctaly that flow divider is adjustable. You see the turn valve on the left side between the two big lines. I used to have a 504 and the pump was getting wore. I adjusted that valve so it dumped less oil and improved speed of functions somewhat until I got around to replaceing the pump.
