Re: High pitch Hydraulic or Gear noise after new pump ins...
Posted by Allan In NE on October 01, 2008 at 02:28:26 from (148.78.243.26):
In Reply to: High pitch Hydraulic or Gear noise after new pump install... posted by charles todd on September 30, 2008 at 19:16:57:
Dunno,
I'm inclined to go along with Scott's line of thinking; you're overpowering that valve. Does it get hot?
I'd try to open 'er up a little and see if the steering will take a bit more of the oil.
Really, really doubt if the problem is the 90-degree fitting.
If it were gear whine, one would think you'd hear it at the pump; not this far downstream.
Good luck,
Allan
