Re: ahhhh....here's where I'm headed
Posted by DennisT on October 01, 2008 at 07:47:50 from (63.174.56.9):
In Reply to: tips for looking at a Farmall 100? posted by DennisT on September 30, 2008 at 22:57:24:
Thanks; good info. I've got a Ford 1841 Industrial loader tractor that needs a lot of rebuilding. I've been putting it off. The Ford will be my heavy duty loader tractor...down the road. I like Farmall Cubs, but not the limited/dedicated attachments required for them. A Super A or this 100 would be perfect here for cultivating and working around our windbreak, etc. Your comments about the 500# limit for the 100's loader is important for me to know. The loader on this 100 is the old, "tube framework," style from long ago. I can't tell from the guy's photos if it is totally factory, but probably.
When you referred to your, "Farmall 1000," loader on your Super A, is that a tube frame loader that sits a little like an A-frame over tractor? Narrow bucket, with single vertical cylinder positioned behind the bucket, in front of the tractor grill? If so, this 100 has the same loader.
So for yard work/windbreak, this 100 would be perfect. BAD side is, what damage has been done to the tractor's front end by past mis-use of the loader by previous owners use?
Seller said no 3-point, which I expected. PTO, yes, but no comment on a single-point lift.
Are under-belly implements hard to find for these?
Thanks for listening, Dennis
