Re: A starting problem
Posted by glennster on October 01, 2008 at 13:59:14 from (99.131.129.77):
In Reply to: A starting problem posted by 7lazy77 on October 01, 2008 at 13:48:37:
could be a number of things. first, check the battery, make sure it is good and fully charged. if necessary, try and use another vehicle and a set of jumper cables, see if it cranks over. if not, you can eliminate the battery. if the cables are good and all the connections are clean and tight, look to a starter problem. i am pretty sure the a uses a saddle mount switch on the starter. could be the contacts are worn. or could be a bad starter.
