Re: High pitch Hydraulic or Gear noise after new pump ins...
Posted by charles todd on October 03, 2008 at 18:35:28 from (205.242.95.135):
In Reply to: High pitch Hydraulic or Gear noise after new pump install... posted by charles todd on September 30, 2008 at 19:16:57:
Its more like an old window unit! I am not going to do the 90 degree fitting now. When I closed the flow divider screw all the way in the noise and the steering stopped. So I now know the noise is in the divider. I am going to accept the noise until I tear into the flow divider and see how it looks. The Blue Ribbon says the "cartridge" it replaceable. If I need to this, I'll bite the bullet and call the local Case/New Holland dealer.
Within the next few weeks, I hope to plumb in the 3-spool loader valve and see how it all sounds. I am going to use the pump output to feed the "IN" on the valve and then use the "OUT" to feed the flow divider. Return will go to the fill plug at the IPTO housing. I know Allan NE suggested the PTO pump, but I have passed the point of no return and I have all the fittings and hose.
My proposed new hydrualic layout...
third party image
I have spent a small fortune on this tractor. It should be almost equal to a good, newer one by now!
Charles
