Posted by mjs on October 06, 2008 at 17:32:18 from (208.114.35.15):
Measured end of pto shaft to center of hitchpin on baler and it is 15 inches. The book says 16 inches needed. Put tractor/baler in tight enough turn(maybe 40% as tight as a full turn) and engaged pto and got the noise I was hearing in the hay field. Got out to listen and pretty sure it is coming from baler driveshaft. It did shorten up about 2 to 2.5 inches when I turned but didn't bottom out. Still had about 1 to 1.5 inches. I think the conclusion is to lengthen out the drawbar but problem here. My drawbar only has 2 holes up underneath and they are about 8 inches apart. If I lengthened out the drawbar, I'm afraid the pto shaft will be extended too far. Am I wrong? The only thing I can think to do is remove the drawbar and have another hole between existing ones milled into it. What are you guys thoughts?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
