Re: 1066 PTO Noise - Update
Posted by Allan In NE on October 07, 2008 at 01:34:06 from (148.78.243.24):
In Reply to: 1066 PTO Noise - Update posted by mjs on October 06, 2008 at 17:32:18:
Trying to get this straight in my mind.
You're operating a 1,000 rpm PTO with the drawbar in the forward/storage position?
That's way too close unless your drawbar has an extended, mounted, clevis type hitch bolted to it.
If the drawbar is just the standard one-piece setup, the under-belly pin should be in the front hole.
Second hole is for storage to allow you to get the drawbar forward and out of the way when using 3-point equipment.
Don't see how you ever got it hooked up that way unless you hooked up the PTO first and then backed into the hitch pin?
Allan
