Posted by old on October 06, 2008 at 19:15:42 from (4.245.1.82):
In Reply to: stuck cub help needed posted by seabee (Ga) on October 06, 2008 at 18:52:24:
Never ever try to pull a tractor with a stuck engine or it can/will cost you big $$ to fix what may brake. Pull the starter off and make sure its not locked in the flywheel and hope you did not brake teeth on the flywheel. If thats not it then blow out the cylinders and then fill with ATF, if its going to come free ATF will do it because it does 2 things. I cleans out the rust and lubes at the same time. BTDT on many many engines and have always had good luck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
