Re: 340 U Hydraulic Fitting size and type?
Posted by tesmith66 on October 07, 2008 at 04:29:24 from (130.76.96.19):
In Reply to: 340 U Hydraulic Fitting size and type? posted by brmtdg on October 06, 2008 at 12:27:03:
I was thinking of threading the hole in the lower cover and having a hose made up, but I didn't want to restrict flow or damage the cover. My hose is leaking out of the crimped ends, not the fittings, so I assume the fittings are good and can be re-used. At least I hope so.
