340 U Hydraulic Fitting size and type?
Posted by brmtdg on October 06, 2008 at 12:27:03 from (71.57.218.99):
Reattaching hydraulics supply line to the 3pt hitch on a 340 utility. Does anyone know what the fitting type and/or size is of the port that the belly pump output hose attaches to at the hydraulic control block(in front of seat)?
There is currently no hose to go by, just a plastic pipe plug cross threaded in. The port looks to be 1-3/16 with a O-ring surface. Maybe a standard O-ring SAE-14 port is my best guess?
Wanted to ask before ordering fitting. The Case/Ih site has part numbers of the hose and filler plug but I have not been able to cross it to a description with port type or size.
thanks in advance, this forum has truely been a great source of advice and information.
