Re: Help re: speed control on Farmall A
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Chris on March 25, 2000 at 16:27:17 from (64.24.58.140):
In Reply to: Help re: speed control on Farmall A posted by Douglas Stockman on March 25, 2000 at 14:42:04:
A bad spring on my Cub caused a whole lot of slop in the linkage. I could push it forward normally, but had to pull it back ALOT to get it down to the original speed. Does the govenor react to a load by increasing throttle? This may not tell you much if it doesn't, but if it does react my guess would be that the problem is not with the weights or bearing. Check all the external linkages for binding and rubbing. Good luck, Chris
Post A Followup
: Re: Re: Help re: speed control on Farmall A
