Posted by Gary Puckett on October 08, 2008 at 19:57:05 from (24.99.212.123):
I need your help to verify my thinking. Description – 47 Farmall H, still 6 volt positive ground, has lights, new ammeter gauge, new wiring, generator and voltage regulator. Gauge works like it should showing charge and discharge. Question – With lights off and key off and ground cable disconnected,should there be a voltage reading between the battery post and battery cable (disconnected)? I think not, but there is. The battery does not discharge; I just checked it out of curiosity
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
