The H has no electronics in it at all. It is pure switches and relays. When the ignition switch is OFF, there should be no voltage at the disconnected terminal. To be sure, it will not draw enough to matter if there is less than 1/2 volt present. I would suggest hooking up the meter and disconnecting one wire at a time from light switches and ignition, and Voltage regulator (and if they do not remove the draw, reattach them to prevent a mess). Eventually it will go to zero, and all will be well. If your meter is very good, and millivolts are shown, it is possible that no real issue is present. Between the components in an old tractor, and a leak to ground might just be a bit of dirt/ moist enough to carry a bit of electricity. JimN
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
