Re: A Cub starter flywheel problem
Posted by old on October 09, 2008 at 19:32:26 from (4.244.186.248):
In Reply to: A Cub starter flywheel problem posted by Farmallb on October 09, 2008 at 17:19:54:
Sounds like either the bendex/starter drive is bad or the ring gear is bad or has slipped
