A Cub starter flywheel problem
Posted by Farmallb on October 09, 2008 at 17:19:54 from (12.74.196.176):
My starter does not mesh with the teeth on the flywheel. When it DID touch the teeth, it was by a bare 1/32in The ends are wore where they barely touched.Is there a way to reset the starter gear so it comes out further, or put shims behind the flywheel so as to bring it closer tio the starter
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
