Re: A Cub starter flywheel problem
Posted by Andy Motteberg on October 10, 2008 at 13:53:57 from (4.143.220.196):
In Reply to: A Cub starter flywheel problem posted by Farmallb on October 09, 2008 at 17:19:54:
Make sure you have the correct starter. Make sure the flywheel ring gear teeth are in good condition, also make sure the starter drive has good teeth.
