F14 oil pump question
Posted by tractorhank on October 11, 2008 at 19:36:27 from (24.124.104.36):
I am restoring a F14 and when I took the engine oil pan off the oil pump pickup tube was cracked and bent and the 4" pickup and screen were badly crushed. I am guessing someone tried to turn it over with ice in the oil pan as I drained out a fair amount of water. I called my local tractor salvage yard and they said they had one out of an F12 but when I got there it was different. It was not a floating pickup and it was larger. My question is will it work in the F14 as I have not found any good ones out of an F14. Where it bolts to the oil pump with 3 bolts looks to be the same.
