Re: F14 oil pump question
Posted by rustred on October 11, 2008 at 22:31:20 from (209.115.232.65):
In Reply to: F14 oil pump question posted by tractorhank on October 11, 2008 at 19:36:27:
the 12and 14 is the same engine. you can have either an oil pump with the solid screen or floating screen. i would use another pump, other than mixing pieces, due to the fact that those are matching machined surfaces.
