I think if you try to weld it, it will still seep. JB Weld has worked well for me. I fixed many freexe cracks on a small Cat and it does not leak a drop and it seemed as hard as the cast when I ground it to finish it. Vee it out real good just like you were going to weld it. I used 2 coats and let it cure a week in hot weather. I have seen Cat engines plated behind the injection pump where thay are known to crack, that works too. Remember it is only the water jacket and the casting is likely quite thin. I think an attept at welding can cause more harm than good.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
