It can be pinned - by far the least risky way of fixing it. I would not recomend arc welding it - the only way to weld it with heat is to bring the whole block up to high temperature -unless you are just welding on the very corner of the casting. And pinning is by far the best looking fix cosmetically. Bolt a plate on it if you want - but it will look like hell and probably still seep - unlesss you have silicone oozing out everywhere. I have repaired a few blocks and heads by pinning and have had zero problems, but it is a bit time consuming.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
