Re: F-20 Cracked Block - - Solutions other than replacment?
Posted by Scott Rukke on October 12, 2008 at 18:41:14 from (67.183.230.71):
In Reply to: F-20 Cracked Block - - Solutions other than replacment? posted by Pete in Holland, MI on October 12, 2008 at 14:08:41:
You might think about brazing it also. Very easy and it works well with cast iron. Just be sure to heat slowly and cool slowly. The bronze brazing rod is extremely strong. I brazed a piece that broke off my F-20 block and it works great. I ground a groove then filled it with the brazing rod and ground it smooth and you can't even tell it was repaired.
